RCU Forums - View Single Post - Insight build...another wood roach.
Old 03-30-2005 | 11:56 PM
flyintexan's Avatar
flyintexan
Default RE: Insight build...another wood roach.
It was time to cut and fit the top, forward fusebox sheet which is made from a single piece of 1/16" ply. This top piece will tie in all the forward fuse formers and the back of the firewall. As you can see, it starts as a 6" wide x 30" long sheet. I start by fitting the sheet to the back of the firewall which has the right thrust built in. Once I get a good fit there, I cut the other end to length so that it ends where the rear top fusebox sheeting starts. As you can see (barely) in the second pic, all the lightening holes are laid out in pencil. Then I proceed to waste approx. 90% with the scroll saw. I glue on what's left with minimal amounts of epoxy. I also add a 1/8"lite ply firewall brace midway between the top and bottom of the fusebox (glued in with epoxy). With this in place, the 1/8" lite ply firewall is now plenty rigid....in my opinion.
ID:	251753   Click image for larger version
ID:	251754   Click image for larger version
ID:	251755   Click image for larger version
