RE: Learning to Harrier
Spoilerons are fine but first you must be sure your set up right. You need the right airplane. Many 3D models have a HUGE airfoil and a square wing. To me it helps if there is no huge wing b/c you can reach a stall quicker. Its also very important that your lateral CG is right. And if you have split elevators they must be throwing exactly the same amount (can not be different).
