RE: possible oil problem
Well, if it's 'oil', it is probably coming out of the exhaust system somehow.. slightly loose muffler bolts, loose muffler, or perhaps a loose or broken tank pressure fitting?
If it's a four stroke engine, the engine discharge vent on the bottom may be disconnected (if you ran a tube from it to the outside of the fuselage. Just a few.. maybe someone else has other ideas.
