RE: Crutch construction?
Abu: Yes. That is my understanding. And it does not have to be a horizontal split as I described. I think the Guillows was a vertical split, but in their case, the stringers were complex in shape. With the horizontal split, the stringers are merely bowed to the correct contour. Both work equally well, when you have other than square fuselages.
Les
