all around the carb and under the needle valve and the bottom left of engine.
Might not have a good seal between the carb and the engine body. Howerver it could also be leaking from the front barings and being blown back by the prop.
If it isn't exhibiting any other problem I wouldn't worry to much about it other then checking the barings. After a day of flying my engines are pretty slimy.
