RE: First build - Sig SE started
You bet!! Don't you remember when you built your trainer (unless you did an ARF) and after you put the two wing halfs together you put the strip of fiberglass at the joint? The covering went over it just fine. I'll be glassing the entire airframe of the P-47 I am building but then I'm going to paint it, but I thought about covering it with ultracoat as well.
