RCU Forums - View Single Post - pitches down, balanced
Old 03-31-2005 | 10:05 PM
michpittsman
Default RE: pitches down, balanced
Did you have to add weight to the tail to achieve balance? This airplane is notoriously nose heavy unless the battery pack and/or servos are moved back behind the wing. MEASURE how far back the balance point should be, then place strips of tape on the bottom of the wing close to the fuselage. Then your finger tip method might be precise enough to be accurate. Jim
