RE: newby needs rossi 65 help
That engine is just awesome once you master it.....3.5 hp rating with NO NITRO!!!!!
Must have tuned pipe.....got one?
Fuel mix..........have used these in helicopters many hours............ 12% Klotz, 1% castor, in one gallon of methanol. High needle set at 2-3 turns out and the idle set the same. (on that engine set the idle on the bench and then set the high side.
If you have problems send me a PM and we will exhange phone numbers. It is an awesome powerplant when you get it right. Best damn glow engine out there, but needs the right fuel mix.
Jack
