RCU Forums - View Single Post - Need help with NexSTAR ARF
Old 04-01-2005 | 10:40 AM
NITEHAWK1957
Default Need help with NexSTAR ARF
I am building a NexSTAR ARF after an unpleasant greeting with a tree while flying the 1st NexSTAR, I have ran into a small problem, the manual says the fuel tank comes assembled ( IT DID NOT COME ASSEMBLED )and theres no instructions for assembly, am I correct that the hose & Clunk are positioned on the bottom of the stopper with the klunk not touching the back of the tank,and the fill and vent ( MUFFLER PRESSURE TUBE ) are on the top with the pressure tube being bent towards the top of the tank....? Also, I would like to strengthen a few areas so how do I go about thinning epoxy, what do I add.......?
I also have to glue in a peice of stock to hold the tank in place as the manual says to tighten the assembled stopper after sliding the tank through the hole in the firewall and the swollen rubber will hold the tank in place ( IT STILL SLIDES OUT WITH THE TANK EMPTY ), so I want to make sure it is assembled correctly before I glue in a piece of stock behind the tank to hold it in place........Any help or advice would be greatly appreciated......
