RCU Forums - View Single Post - WM Chipmunk question
Old 04-02-2005 | 10:44 AM
rickenberg
Default RE: WM Chipmunk question
Hi There Guys!!
Kirk Brimmer - you say you are using a YS 91 in your S/Chipmunk...
I'm in the middle of building my WM Super Chipmunk 90S and have an engine mounting problem!
I'm mounting a YS motor (FZ91 type) and have trouble with the location of the throttle pushrod exit through the firewall. The throttle linkage on the motor does not line up with either of the optional pushrod exits (upright mounted or side mounted).
Also, the throttle linkage is obstructed by the gusset of the plastic engine mount (once the engine is fixed in the plastic mounts).
Does anyone know a solution to these 2 problems?? Can you email me at [email protected] ?? I'd really be grateful!!
Adam Rickenberg
