Jumping Jack Set Up for 3D
Hi,
I have decided to enter into the 3D electrics world with a Fliton Jumping Jack. I would like you, if possible, to comment on my potential set up which is the following:
Motor: AXI 2808/24
Speed Control: Jeti Advance 30-3P
Battery: Thunder Power 11.1 V ,2100mAh, 3 Cells, 127gr or Akku Kokam 11.1V, 2000 mAh, 3 Cells, 145 gr
Servos: 4 Hitec HS-55
Prop: APC 11x5.5
I have read various threads in RCU about the model, but have not seen any people using an AXI motor, most use Lehner, Hacker, etc. Would this motor offer reasonable 3D perfromance you think? According to a German dealer this motor can produce a static thrust of 1100gr at 22.5A which sounds ok to me if we assume that the model weighs around 600gr.
So what do you think?
Rgrds,
Nik
