RCU Forums - View Single Post - Difference between OS FX & AX ABL
Old 04-02-2005 | 07:40 PM
Ed_Moorman's Avatar
Ed_Moorman
Default RE: Difference between OS FX & AX ABL
The "H" engines are for helicopter use. They have the big heat sink head. You probably wouldn't want one of those in a regular airplane.
The OS .46AX is the follow on engine to the .46FX. It has a slightly different crankshaft, wider forward transfer port which led to a 4-bolt head instead of a 6-bolt. This led to a different design cylinder and head. It also has a separate needle valve assembly instead of the cast-on one on the FX.
