RE: Is my Edge to fat?
I was wondering if you have pulled a line from the wing tip marks to give you the location of your CG machine Tom gives all CG points to be used at the wing tip Also if that is your ignition battery in the pics you might want to make sure you get a real clean range check I have seen a lot of problems with the battery and ignition wiring that close to servos. Just my opinion of course!
