RCU Forums - View Single Post - Please help, ASP 75 cutting out.
Old 04-03-2005 | 11:44 AM
karolh
Default Please help, ASP 75 cutting out.
My ASP75 is fitted with one of the new series ST 75 carb for fuel economy, and the combo has always performed well. After recently replacing a split fuel tank and doing a carb strip down, I am having a problem keeping the engine running at idle.
The top end is fine, with a reasonable midrange which is typical of the ST carb, but is not a major problem.
The engine idles normally on an OS #8 plug with the starting battery connected, but as soon as the battery is removed the engine quits, yet it idles well with a Fox miracle plug when the battery is removed.
I have tried several new #8's with no change, what could be wrong. I would like to continue using the OS plug as it gives a good midrange response. I have checked all fuel lines for leaks and pressured the system, and used high temp RTV silicone to help seal the carb neck / engine to guard against a possible air leak.
What am I missing here ??
