RE: DA 100 VS 3W106 for NEW compositarf
2.6mrod:
The loctite bearing compound is normal procedure to make sure the bearings don't move in the case. However, the one case half has a bearing surface that wasn't machined properly. That can't be fixed with loctite. They should have replaced the case. I would send the photo to 3W modellmotoren in Germany with a letter explaining the service you didn't get from your distributor.
