tIANci... where do you get your transformers hooked up? I know a place in Atria, PJ which does it. How much would it cost? I am getting pretty tired of having to charge my sealed lead acid battery to power my charger to charge my nicd, nimh and lipos.
I even tried hooking up a power supply from an old pc but I guess I got the wiring wrong. I blew out one phase off the fuse in my house
Thank God I didn't get fried along with it. There are so many wires that come out of the PC's power supply and it's usually switched on by a button on the PC case and the Power supply is usually hooked to the mother board for that to happen. So I wish someone will tell me which wires are good to connect to a physical switch without the use of a pc case & motherboard. The problem is.. there are too many different types of power supplies around.
