RCU Forums - View Single Post - newby needs rossi 65 help
Old 04-04-2005 | 08:33 AM
Helijack's Avatar
Helijack
Default RE: newby needs rossi 65 help
No, 1% was not a typo. Those engines run best on 11% oil, I didn't have the balls. I run them at 13% I also found out they run 40 degrees cooler with the 1% castor. The oil I found most successful was a total of 13%. Best temps, best starts, most consistent.
Now, I must also add that I only run my glow machines with a header tank and the "Uniflow" system. This gives a consistent pressure to the fuel system and the engine is constant.
Rossi themselves recommend 10% castor.
Reliability? Treated properly and as outlined above, I only had to auto in one time in 7 gallons of fuel, and that was my fault. Jack
