RCU Forums - View Single Post - NEED SOME HELP
Old 04-04-2005 | 10:01 AM
siclick33
Default RE: NEED SOME HELP
I use the Jet-tronics valves also.
I would recommend them for the gear but not the brakes. The valve works, for brakes, by switching on and off at different rates to give you different braking levels. This means you can empty an air tank in a few seconds.
I don't know if the other electronic ones work the same, but my next model will have a manual brake valve.
