RCU Forums - View Single Post - Another BME 110 question
Old 04-04-2005 | 01:38 PM
Geistware
My Feedback: (16)
Default RE: Another BME 110 question
I really don't think you have to worry about running the engine too lean and causing damage. Make sure you are not running your oil/gas mix on the lean side and you should be OK. Gas is not like glow. Running the engine lean causes excessive heat but if you keep that to a minimum you should be OK.
