RE: What part turns a plane
"Up elevator doesn’t turn the airplane" This is absolutely true when you use a bumping method to keep the aircraft on course. However, to make a U shape turn or constant altitude turn, up elevator is held in throughout the turn. That aerodynamically means that the up elevator turns the aircraft while making a 180 degree-turn.
