RCU Forums - View Single Post - NEED SOME HELP
Old 04-04-2005 | 09:05 PM
tcblr
Default RE: NEED SOME HELP
Yes, the Jetronics valve plugs directly into your receiver. I prefer a slider switch for mine.
I don't think you will have a problem with weight considering you are using the Wren 54 SS although it is better to stay lighter if possible. I have seen this plane on the 12# thrust engines perform very well. I have the Simjet 1200 SP in mine which produces about the same thrust as your Wren and it's a rocket.
how much fuel capacity will you have?
Brandon
