RE: 9303 travel adj on Ailerons Question
Danny, thanks for the reply.
I tried following the set up as shown on the JR web site for aerobatic set up by Baron Johnson. It also seems to match what the 9303 manual describes for flaperon setup.
I tried what you said and it still cannot move the right aileron for travel adjust.
The second line down has this info:
RAIL L 83% R 83% LAIL +100% -100%
When I highlight and select the L 83% I can cause the L aileron to adjust up and down. It has no effect on the R aileron.
I then move the stick to highlight R 83% , then select it. Changing the value does not cause any change in either aileron.
This is the same result I noticed my first attempt to do a travel adjustment.
I then scroll to LAIL +100% or -100%. When moving and changing either the +100% or -100% neither the left or right ailerons change any position. The programing still seems incorrect. I may still be missing something.
I have no dual rates, flight modes or any programing mixes.
