RE: Range issue, could use some help
ok, you edited the question and it is now within my understanding. With the PCM receiver the baseline was 12 steps, while previously on all airplanes it was a miniumum of 50 to 55 paces. With PPM, last night simply placing the transmitter on a table maybe 20 feet from the airplane with an 8103 transmitter ant. down, I was getting servo jitter in the airplane with the ant. in some positions but not all positions. Then I started the test by placing a receiver and a servo all over the airplane to help determine where the noise was coming from. Tonight I will start removing items from my control panel to see when the noise goes away.
Sean
