RE: 9303 travel adj on Ailerons Question
Adjusting LAIL should have no affect on the right and vice versa. I'm not understanding, in one paragraph you state that adjusting LAIL is adjusting the left, then in another you say it has no affect. Adjusting the values immediately next to RAIL should adjust the right aileron which is plugged into channel 2 and adjusting the values immediately next to LAIL should adjust the left aileron. This should be visible on the servo monitor after you have made the adjustments.
