RCU Forums - View Single Post - tachometer
Thread: tachometer
Old 04-05-2005 | 10:00 AM
CGRetired's Avatar
CGRetired
Default RE: tachometer
Piper.. that's exactly what my instructor taught me, but we use the pinch the fuel line way to see where the needle valve is set. I get the same either way so I feel that both methods work and work well. I also like keeping that mixture a tad bit rich, again, for both reasons you said, prolong engine life and because the engine will run leaner in the air as the tank empties and as the aircraft goes vertical.
