RE: Jumping Jack Set Up for 3D
Thanks Josh! I'll go for it then.
I'm planning to use this motor mount with the AXI, have a look.
What is your estimation regarding the battery duration of the TP LiPo? Will it last for about 10 mins or so till it dies you think? I'm intended to play with the throttle a lot so I'm not gonna run the motor at full throttle for a long time.
Also, can you please consult me on the wing modifications required to avoid any construction failure? I've read of some nasty incidents during 3D flying mostly.
Final question I will get the JJ because I like its design features and flying capabilities a lot but how would it compare with the mini Funtana? I've been hearing a lot about this plane, that's why I'm asking.
Looking forward to your reply.
Thanks and regards,
Nik
