RCU Forums - View Single Post - U-Can-Do 3d 46?
Old 04-05-2005 | 09:07 PM
  #1670
kokamo's Avatar
kokamo
Default RE: U-Can-Do 3d 46?
perkinsm.....Looks good bud, But I think that thing needs to see a heat gun!!! HA HA HA! I see that you used your "wooden squares" that came with the kit to install the cowl. What I did was not use them,(I started to tho) Instead, I drilled holes for the screws in the side of the firewall. Look at my other pics and you might be able to see. (aww heck, I'll post one fer ya!) I know this is not neccisary but it does take off a couple of grams. Not much but every little bit helps right?!
BTW.....whats with that other UCD in the pic, right above your new UCD? I can see part of that landing gear brace you made.
Joe
