As a remainder, how to make an FMS PPM to PC serial cable. For USB, add a serial to USB converter cable.
Based on a PIC 12F675. Ok for 98, ME, 2K, XP, portables.
[î]needs a TTL compatible PPM signal ( (*) and ref to doc), which is the case of most transmitters[/i]
Schema:
http://www.jdm-nivelles.be/fichiers/...cteurs_PCM.pdf
PIC hex file:
http://www.jdm-nivelles.be/fichiers/fms/pcmcab.hex
Printed Circuit:
http://www.jdm-nivelles.be/fichiers/...it_imprime.jpg
"Manual" printed circuit:
http://www.jdm-nivelles.be/fichiers/...uit_manuel.jpg
Tools to help you:
Virtual scope on PC audio input (mike) (to find your PPM signal):
http://polly.phys.msu.su/~zeld/oscill.html
COM signal analyser:
http://www.jdm-nivelles.be/fichiers/...32analyser.exe
PPM signal analyser (has COMx and audio interface inputs):
http://www.jdm-nivelles.be/fichiers/fms/Analyser31.exe
Transmitters info (how to find your PPM signal or make a buddy cable):
http://users.belgacom.net/TX2TX
All docs and other softwares (viewing plane or helico, record a flight, ...):
http://www.jdm-nivelles.be/fichiers/fms/SPCMliste.htm
Philippe
Brussels Belgium
JDM- Nivelles
(*): TTL signal: low < 0.8V, high > 2.4V. Check with scope.
Edit: remark from a user on the FMS forum (
http://cgi.ethz.ch/~mmoeller/fms => Forum: it is in English ): one could use a lower voltage zener (3.3v?) , still be in the PIC specs at 4MHz, and achieve a lower "high" voltage. NOT TESTED !
