RE: 9303 travel adj on Ailerons Question
Yes, that is what they will all show when flaperon is active. You need to verify that you have the servos plugged into the correct channels, the right aileron should be plugged into channel 2 and the left in channel 6. You should see the affect of the travel adjust setting in the servo monitor. If the travel adjust changes the amount of movement in the servo monitor, then the problem is in your aircraft. The LAIL setting will ONLY affect the left aileron, and the RAIL setting will ONLY affect the right aileron.
