RCU Forums - View Single Post - How annoying is that?
Old 04-06-2005 | 11:43 AM
seanreit's Avatar
seanreit
My Feedback: (60)
Default RE: How annoying is that?
You should be able to resheet with poly glue, the foaming action may fill in the areas that pulled out??? If you provide a picture, I can tell you for sure. I've filled in some gaping gaps with that stuff and all works fine. You can punch a 3 inch square hole in a foam wing and just sheet over it with nothing structural in the hole and still have a very strong wing! I have many cases of proving this is true!
