Gorilla Glue ??? Aileron hinges???
I normally use 30 or 60 minute epoxy on robart hinge points... but after using gorilla glue on my foamies, I decided to give it a try on the Wildhare wings....
I didn't get alot of foaming, but the hinges seem more than strong enough....
Should I be concerned about the lack of foam????? There was a small amount of foam after the first 10 minutes, and just a little foam 10 minutes later... after that..... nothing....
I followed Tom's directions... used water to moisten the drilled holes... coated the holes with gorilla, and put a small amount on the hinges themselves....
FWIW, I going to using the gorilla glue from this point foward when using robart hinge points.... fast, easy, and clean... IMO..
