RCU Forums - View Single Post - muffler gasket
Old 04-06-2005 | 03:53 PM
Montague
Default RE: muffler gasket
fwiw, Loctite brand foruma 222 (purple) works pretty well for me. Most "blue" threadlocker is meant for larger bolts (larger than 1/4"), so it doesn't hold well on smaller bolts. Some red is also that way (Loctite makes a ton of different forumlas that are "red").
They have high heat, oil resistant forumlas that will easily handle anything our engines throw at it.
fwiw, I also ditch any gasket, use bare metal-to-metal, and usually use a split washer under the bolt head. Sure doesn't hurt any.
