RCU Forums - View Single Post - basic questions on pull pull
Old 04-06-2005 | 03:58 PM
strulag's Avatar
strulag
My Feedback: (-1)
Default RE: basic questions on pull pull
Here it's deflected all the way. On the first one you can see how much the wire has moved towards the middle. On the last one both of them are very loose sine there's nothing acting on the rudder.
I also have a question...When I put the arm on the servo it's not completely perpendicular to the servo when the servo is centered. What do you do in that case? Do you just leave it like that and then hook the rudder at neutral (i get a little bit of binding on one side) or do you trim it to be perfectly perpendicular and then hook the rudder (I noticed in this case the rudder doesn't have same travel both ways) Thx...
ID:	254855   Click image for larger version
ID:	254856   Click image for larger version
