ORIGINAL: downunder
Judging from that, the amount you've been using wouldn't have any noticeable affect. You could try using 3-5% acetone which seems to be quite helpful especially in zero nitro fuels.
our methanol (I'm in Greece) has 5% toluol (tolyene) in it. I don't use nitromethane.
I was adding 3% aceton for a long time until someone said that toluol has the same effect as acetone.
and this amount (8%) would higher the engine temp.
it actually did.even without acetone it does. but should I add acetone for some reason? i didn't saw any performance differences though.
btw.
pure methanol or nitromethane in a reasonable price is impossible to find here.
