RE: Planes ballooning on landing .... ideas??
DP - before I would change any of the hard stuff ( CG or
thrust) I would try spoilerons in your landing mode. If you
have JR, use the landing system on a 3 position sw and
set two values for spoilers, eg, 10 and 15 degrees. Next
time out play with it up high to see what it does. Should
dirty the airplane sufficiently to allow you to fly it in
with power (pulse the throttle) and keep the nose
down.
