RCU Forums - View Single Post - Quick help please
Old 04-06-2005 | 09:47 PM
jefx's Avatar
jefx
Default RE: Quick help please
ORIGINAL: icenutz
What would you do if you LST's rear end severely flew up over every bump and jump on the track causing a noise dive????
I know you can level the truck with gas and brake in the air, etc. etc. But this is to dramatic for that. What I am looking for is would you stiffen the rear suspension, lighten it, heavier oil, lighter oil, springs etc. The front absorbs the bumps well but the rear end even flips the truck even over little Moguls.
Tell me what you would change. I have the first race on Sunday and I want the LST to represent well!!! Tomorrow is my only day to work on the truck before then.
Thanks Much!
Thanks Much!
Well first you should tell us your current rear shock setup. But it sounds as if you have too heavy of a spring with too light of an oil, or possibly too heavy of a spring and too heavy of an oil, or possibly too light of a spring with too light of an oil.
