RCU Forums - View Single Post - Quick help please
Old 04-06-2005 | 09:57 PM
icenutz's Avatar
icenutz
Default RE: Quick help please
Did you ever watch the TV show, IN A FIX, they finish house projects that the owners started but then could not finish. I need that service for my LST.
OK- here are all my mods. Carbon Fiber chassis an upper plates, FOT tranny (works great), I put lite sway bars on front and rear, and threaded shock bodies. As for the shocks themselves, front has 30 weight oil with black springs, rear has 40 weight oil with silver (stock) springs. I do not believe I intended the spring set up that way it is just how it ended up. I also put in jet vent shock pistons for the hell of it. I adjusted the shock bodies through out the day but and found some difference but in the end my ass end was flying high in the sky. I need to be able to come of those bumps and jumps more level.
I also intended to experiment over the last few weeks with diff oil so I put 50 in front and rear. I noticed no turning improvements.
