RE: Avistar 40 w/ .46AX
Thanks for all of the replies. The PDF of the manual will help a LOT. As you say, not all of it applies but just knowing how something is normally done for a similar plane I should be able to figure things out a little easier.
I won't forget to epoxy the cut... thanks for that tip.
Is it ok to do the break in on the plane as suggested in the manual or should this really be done on the bench?
Thanks again!
