RE: WHY is this thing so TAIL HEAVY??
Crashem,
You might have the MK I instead of the MK II. The MK II that I have is definately a sheeted foam wing. The way I found out for sure is when I joined the two wing halves, I drilled a few small holes in the end caps for each side for the epoxy to key into and found that on the other side of that thin plywood was foam.
