RE: Jumping Jack Set Up for 3D
The JJ flies MUCH better than the Mini Funtana.
That mount looks nice, It should work out well. The TP 2100 will run for about 10-15 minutes I would imagine on your setup.
Epoxy the wings into the fuselage, then, Whick thin CA in-between the spar joints, to hold the two spars "Together" then, sheet over the spar Joint with a piece of 1/32th balsa, on each side of the spar, inside the fuselage. This is bulletproof!
Josh
