RCU Forums - View Single Post - propelene oxide
Old 04-07-2005 | 05:12 PM
tdriver
Default RE: propelene oxide
ORIGINAL: Fuelman
tdriver,
you will be just fine without adding acetone, there is no need with the methanol you describe as having toluol in it.
I see, thanks.
are there any other "side effects" toluol may have compared to same fuel without toluol in it?
I did ones a comparsion with the same mix but wih pharmaceutical methanol (99.98% purity)
I noticed much crispier accelation with it. (99.98%) and the sound was also a little heavier. (more bass)
could this difference be a effect of the toluol , or is this a sign that water is in the fuel?
I have tried many times to figure that out,but no luck .
