I launch high powered rockets, you should make shure when you lanch it get a 1-2 foot launch rod on your plane and big fins on the rocket also just use small engines like 1/4 A, these are small engines and sometimes the rockets go every where. Also make shure your wires aren't tutching each other or they won't work and make shure you got the igniter all the way in and really held in ( instead of the plugs that come with the engines use masking tape ). For first time testing reasons also launch your rockets right after you pull up also with a recovery sytem on your rocket. always use a recovery system because if it missis the other aircraft you can recover it and use it again. Use a deflector sheild to keep your plane from lighting on fire and aim up.
Good luck and don't be like ralphy
ORIGINAL: Wingman1331
Ok heres my idea: it involves taking apart the SCM and making all x-port enabled planes to instead of the soundwaves of the SCM to fire unguided rockets (small rockets using the estes engines) to hit another plane basicily destorying it (if you hit it!) I kow it is possible and i am working on the first test version now but i might be delayed doing stuff because i just sprained my right wrist and it hurts. If anyone wants more info PM me and I can give you the whole plan.
