RCU Forums - View Single Post - CRAZY IDEA!!!!!!!!!
Old 04-07-2005 | 09:54 PM
  #63
123365
Default RE: CRAZY IDEA!!!!!!!!!
very true- like your idea-
ORIGINAL: m00se
I think the biggest impact on the plane will be reduction of drag after the rocket leaves. The thrust from the rocket engine (action) will push the rocket off the Stryker (reaction).
Glacier Girl- I used to mess with model rockets. Exactly how do you disable the 'chute charge in a solid fuel engine?
For the record- I think this is a crazy idea, and if you use it (assuming it works) anywhere near a populated area you are going to give R/Cers a bad name. But I still want to see the video if it works
works perfectly
