RE: Smart fly optical ignition cutoff setup
I went battery,switch,cutoff, regulator, ignition. there is a little bit of draw on the cutoff so it has to be on the other side of the switch so it doesn't drain the battery.
I am thinking of elimanating the ignition switch all together. The ignition will only work if the reciever has a signal. I also used Aux 4 as the channel on my 10X. This put it on a dial instead of a switch, this way it makes it more difficult to accidently kill the engine.
