RE: need to level horizontal fin...how?
A good way to get the stab off the fuse is to use dental floss. I had to do it on my Elder 40. Checked and re-checked, but when the glue set it was not straight. A fellow member at the field told me about using dental floss. It took about four or five lengths of the stuff, used as a saw, but it worked great. Just be carfull as you saw through the glue joint that it stays in the glue joint. Hope this idea works as good for you as it did for me. Good luck & happy flying. The Wine Country Flyer-John
