RCU Forums - View Single Post - Thrust angle question
Old 04-08-2005 | 12:39 PM
Quicksdraw MaGraw
Default RE: Thrust angle question
I measured the thrust angles from the motor mounting stick supplied with the kit and then transfered those angles to the glow mount. It is just slightly nose heavy using factory CG. This plane has two wing locations, I'm using the rear one. It's supposed to be the less areobatic more precision location.
I think I ended up with 3 degrees right and 2 down. I can check later.
CP, you think flat on the wall would be better?
