H9 Edge 540
To fix the gear, just some some light ply, a little balsa tristocking, and some fiberglass. It wont add enough weight to notice, and the gear will be much stronger. Also go over the seams on the covering with your heat iron to reseal them. I've seen a few seams on this plane start to pull up, but 5 minutes with the heat iron will fix it.
