RCU Forums - View Single Post - RING AND PINION
Old 04-08-2005 | 08:04 PM
MassiveMods's Avatar
MassiveMods
Default RE: RING AND PINION
do you mean the ring and pinion on the front and rear diff ? if so you would shim the diff to make better contact with the pinion, if you shim the pinion it may make contact with the diff body under power..
