RCU Forums - View Single Post - RING AND PINION
Old 04-08-2005 | 08:25 PM
MassiveMods's Avatar
MassiveMods
Default RE: RING AND PINION
yeah you can use the small shim spacers , you only need to shim it say 1 or 2 shims, they slip over the end of the drive cup and rest between the bearing and diff case, they can be a little tight to get in but they do fit.. they are really thin , like .1 mm or .2mm
