RE: ABC...wrong break in?
Fuelman, a test on only two engines is nearly meaninless. There can be enough tolerance differences between the two to account for any differences. To be a valid test, you would have to run identical tests using at least 10 engines, preferably a 100, under each condition and then noted any differences or trends. While your test are interesting, they prove nothing unfortunately.
